MHINO
Apr 15, 2021Tutor
can not connect with my Model EX8000
Hi, I need to go to my wifi to select de "NETGEAR_EXT" , but it just don't find it . The WPS doesn't work either .. i just don't know what to do know.
- Apr 15, 2021
the default login is:
login: admin
password: password
It usually requires you change the password during initial setup.
You can try the forgot password option. But if you didn't set it up or don't remember that either, then you'd need to factory reset it to get back to the defaults.
MHINO
Apr 15, 2021Tutor
well i finally connected with my router ! now i'm stuck with the login admin ? don't no where to find it . Sorry i'm so bad at this 🤦‍♂️. i already have an account , but that's not it ?
Apr 15, 2021Guru - Experienced User
login: admin
password: password
