EricZZ's avatar
EricZZ
Follower
May 12, 2017
Can not get Nighthawk R7000 to allow my Iris by Lowes hub to connect, plaese help!
I have just tried to install my Iris by Lowes gen 2 hub. I can not get it to register with Iris app or with Iris phone support. I have a netgear nighthawk R7000, have it wired in and I went in and se...
  • JamesGL's avatar
    May 18, 2017
    Hi EricZZ,
    Did the hub works with different router? Or is this the first time configuring the hub?
    Do you have other devices that works with the router?
