Pakman3590's avatar
Pakman3590
Cannot access admin login page
I am unable to access the admin login page via gateway IP or routerlogin.net/.com. I am connected through Ethernet and whenever I try to access the admin login page to change router settings, it give an error saying that the device has been blocked by access control. I have tried factory resetting the router several times with no luck. I have also tried connecting to the WiFi and accessing the router with the Netgear Genie app using the default admin/password, but it just times out. I noticed that even after the factory reset, the gateway IP is 192.169.1.1 instead of the default 192.168.1.1.
  • > [...] I have tried factory resetting the router several times with no
    > luck. [...]
       Following the instructions in the User Manual?
    > [...] even after the factory reset, the gateway IP is 192.169.1.1
       Try the reset and reconfiguration with nothing connected to the
    router's WAN/Internet port.  A proper "factory" reset should restore the
    expected default LAN IP address, but if the WAN/Internet port is
    connected to something on the same subnet, then many things are
    possible.  (But I still wouldn't expect "192.169.x.y".)
       I'd also forget the Genie app, and stick to the (simple) web-browser
    interface with a wired connection.
       What are you connecting to the router?  Some Windows system?
    Something else?
  • I also forgot to mention that, while I can connect to the router using Ethernet/wifi, about half the time I cannot even get the device blocked error (the page just times out) and any ping requests to the router time out as well.
    > luck. [...]
    Something else?
    • Pakman3590's avatar
      Pakman3590
      Thanks, disconnectin all of the ethernet cables from the router while resetting it fixed the problem. I guess it was having issues resetting its gateway IP with devices connected.
