OAJ's avatar
OAJ
cannot find wireless repeating function in my R6350 — AC1750 Smart WiFi Router Wi-Fi 5 Dual Settings
I can't seem to find cwireless repeating function in my R6350 — AC1750 Smart WiFi Router Wi-Fi 5 Dual Settings. Its supoosed to be in Advanced->Advanced Setup as given in instructions online but it's not there in mine.
My firmware version of router is : 1.1.0.78_1.0.1
Please help!!!!!!!!!!
  • schumaku's avatar
    schumaku
    There is no Wireless Repeater functionality according to the R6350 Documentation (Data Sheet, User Manual).
    This feature is a relict of the past, and often required very similar wireless hardware on both ends. What configuration do you had in mind?
    • OAJ's avatar
      OAJ
      I wanted to use this as a range extender. I have a wifi router but its range is very less in my room. I wanted to extended its range using this router so I would get better signals in my room
        you shouldn't be using repeaters. They cut bandwidth in half. Set your second router in access point mode
