Kendrite's avatar
Kendrite
Can't access Modem/Router via WiFi
Recently purchased Nighthawk AC1900 and am trying to set it up.
If I connect it via ethernet I can log into the modems login page but I can't via WiFi.
I can connect to both the 2.4Ghz & 5Ghz networks but when I try to access the modems log in page via WiFi it just times out.
I've tried resetting modem and restating the PC.
Is there something obvious that I'm missing?  I just find it strange I can get to the log in page via ethernet buut not WiFi.
Thanks for any suggestions.
  • Edit: And now after changing nothing at all I can access the login scree via WiFi....shrug.
    • michaelkenward's avatar
      michaelkenward
      Perhaps you just started the network in the correct order.
      • Turn off and unplug modem.
      • Turn off router and computers.
      • Plug in and turn on modem. Wait 2 minutes for it to connect.
      • Turn on the router and wait 2 minutes for it connect.
      • Turn on computers and rest of network.
