Zedechai's avatar
Zedechai
Can't access router settings or internet after factory reset
After power outage last week, I have been getting speeds of 30 - 120 Mbps instead of the 500 Mbps I had previously.
Frontier has had multiple issues in the area, so I have been waiting for them to clear it up. Didn't think until last night to try connecting my laptop directly to the modem.   Speed test gave me 500+ Mbps, connecting back to router gave me 120 again.  Restarting router didn't improve things.  Logged into router, and had it check for f/w updates, it said that it was running on v1.0.09 and there were no updates.
I made the mistake of attempting a factory reset on the router, now I have no Internet access through the router, and cannot access the router settings no matter how I try.  I've tried:
  NetgearGenie app - It says: NETGEAR router is not found or is not supported.  Also make sure the device is not connected to the guest network of the router and no IPv6 is enabled. (Which I have verified)((
  Browsing to routerlogin.net or 192.168.1.1 error out unable to connect.  Clearing cache does not help
  Nighthawk app on my phone says it is Disconnected when attempting Anywhere Access, and "Issues connecting with"WiFi" when connecting to WiFi
I have also attempted factory reset after disconnecting modem and all other wired devices, then connecting modem and laptop, then restarting laptop as indicated by another thread I've read, but I am still getting the same issues.
Any other suggestions would be greatly appreciated.
  • I forgot to mention that Wireless connections all show No Internet, secured, while wired connection says "Internet access"
    • > Model: R7000|AC1900 Smart WIFI Router
         Connected to what?
      > [...] v1.0.09 [...]
         Not a real R7000 firmware version.
      > connect.
         What's the IP address of your computer?
         Visit http://netgear.com/support , put in your model number, and look
      for Documentation.  Get the User Manual (at least).  Read.  Look for the
      LED descriptions and "Troubleshoot".
         For later, when you can talk to it again...
      for Downloads.  (For older versions, under Firmware and Software
      Downloads, look for "View Previous Versions".)  Find the kit(s).
      Download the kit(s) you want.  Read the "Release Notes" file for
      instructions.  (In the User Manual, look for "firmware", and,
      especially, for a topic like "Manually Upload Firmware to the Router".)
      When that fails because of a deficient User Manual, try:
            https://kb.netgear.com/23960
      • Zedechai's avatar
        Zedechai
        @ antinode
        >Connected to what?
        Frontier communications provided MoCA Ethernet Adapter Model :FCA251
        >> [...] v1.0.09 [...]
        As stated, I cannot get into the router settings... The above was what I thought I remembered from the night before I could have sworn that it was v1.0.9.xxx but I can't remember for sure.
        IP Address was 192.168.1.2
        I looked up manuals and read through these forums quite a bit.
        All LEDs on the router showed white
        I tried the manual firmware update but got connection refused error, or something along those lines.
        I have since bought another router because I had to work from home yesterday.  If I can get this one back up and running, I will use it as a backup in case I have an issue like this again.
    Things can get horribly out of synch after that sort of chaos.
    Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router kicking in before the modem is ready. That means that they get confused about which is in charge.
    It may help to reboot the whole network in the right order.
    • Turn off and unplug modem.
    • Turn off router and computers.
    • Plug in and turn on modem. Wait 2 minutes for it to connect.
    • Turn on the router and wait 2 minutes for it to connect.
    • Turn on computers and rest of network.
    It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    • Zedechai's avatar
      Zedechai
      michaelkenward
      I found instructions for this reboot and tried this as well.  The only reboot instructions I didn't follow were the 30-30-30 because I read one person's reply that this model did not take too kindly to being restarted like that.
      The Ethernet adapter is a Frontier communications provided MoCA Ethernet Adapter, Model :FCA251
      It is just an Ethernet Adapter.. 1 Coax and 1 Ethernet port are the only ports on it besides power.
      • > Frontier communications provided MoCA Ethernet Adapter Model :FCA251
           And the other end of that is connected to what?  Does its "Coax"
        indicator indicate a good coax connection?
           Which "manuals"?  Thanks for the helpful forum links.
           Including the USB LEDs?  Or does your "All" mean something different
        from my "All"?  If you mean "All LEDs I care about", then I don't know
        which those might be.
           None of that is a useful problem description.  It does not say what
        you did.  It does not say what happened when you did it.  As usual,
        showing actual actions (commands) with their actual results (error
        messages, LED indicators, ...) can be more helpful than vague
        descriptions or interpretations.
