gusperrysmom
Dec 21, 2016Aspirant
Can't access the Router Login page after doing factory reset.
Router: Nighthawk R8000
Version: 1.0.3.26
OS: Windows 10
WiFi access
I have been having intermittent connection problems and Geek Squad said it was a router issue and not a computer (Windows 10) issue and that I should do a factory reset of the router ... which I did.
Now I can access the router with Netgear Genie from my Android tablet, but I cannot access the router from my Windows 10 PC.
My computer is connected to the internet (I'm using it to log this issue) and I'm still experiencing intermittent connection problems which resolve on their own after several minutes or a reboot, but I cannot connect to the router via routerlogin.net or 192.163.1.1. I read the "Why can't I access routerlogin.com or routerlogin.net", but I wasn't able to find anything that helped me.
I'm not real computer tech savy, so the stuff about firewall and Java script went over my head. I did turn off the firewall, but that didn't help. Not sure if I should have rebooted after I turned it off.
Help! Thanks!
It could of course be an ISP problem too.
You could try something like the trial version of PingPlotter and let run ping tests in the background. If your modem has a web admin page, you should be able to ping that, and that will show you any issues between the PC and the modem (e.g., the router). You can also ping some other internet hostname simultaneously (for instance geeksquad.com), and compare the results.
The usual IP address for your router would be 192.168.1.1, not 163.
You can find out your PC's "gateway address" using the guide here: http://www.howtogeek.com/233952/how-to-find-your-routers-ip-address-on-any-computer-smartphone-or-tablet/ That is your router's local IP address.
- gusperrysmomAspirant
Thanks, Stephen. Yes. That is a typo on my part. 192.168.1.1 is the IP address for the router.
Probably you should solve the login page issue before you go back to the internet connection problem. You might need to try a second reset.
