Mrcorvettegolfe's avatar
Mar 30, 2022
Can't connect to 5g
I can connect to my router netgear92 but I can't connect to 5G. This is with any device. On the Ipad it says "Can't obtain authorization" on other devices it just says can't connect.
  • plemans's avatar
    You have the r7000P?
    What firmware is on it?
    What modem/gateway is it connected to?
    have you checked your wireless password settings?
    • Mrcorvettegolfe's avatar
      Mrcorvettegolfe
      You have the r7000P?  Yes it is.
      What firmware is on it?  V1.3.2.134-10.1.66
      What modem/gateway is it connected to? Arris TM1602 cable modem
      have you checked your wireless password settings? Yes it is the same as the 2gz.
      It does baffle me. I can't connect either IOs or android mobile devices.
      I have restarted both the modem and the router several times.
      • plemans's avatar
        Have you tried a simple factory reset on the router and reinstall?
        Push and hold reset for 7-15 seconds while powered on.
