-jon_smitty-
Feb 19, 2018Aspirant
Can't disable 60GHz 802.11ad Broadcast Name from being transmitted
Model: Netgear R9000 / AD7200 Nighthawk X10 Router The 60Ghz LED is lit on the router, and under the "Advanced Wireless Settings (60GHz 802.11ad)", the "Enable Wireless Router Radio" is unchecked, but...
- Feb 20, 2018
-jon_smitty-wrote:
Model: Netgear R9000 / AD7200 Nighthawk X10 Router The 60Ghz LED is lit on the router, and under the "Advanced Wireless Settings (60GHz 802.11ad)", the "Enable Wireless Router Radio" is unchecked, but the "Broadcast Name" is still transmitting. All of the other bands are unchecked and aren’t transmitting, so why is this the only one? I've tried every possible configuration in the router setup, but nothing works. Any idea on how to turn it off?Several reports on the community on 1.0.3.6 firmare (or before) - but most users talked of the 60 Ghz radio LED only, as many don't have 802.11ad equipment to see and use it on air.
Give a try on R9000 Firmware Version 1.0.3.10 - Hot FixCase850 wrote:
Return the R9000 and get a R7800.
As the operator does aparently have 802.11ad equipment to see the 60 GHz interface on air a litle bit a strange advise.
schumaku
Feb 20, 2018Guru - Experienced User
Case850 wrote:Return the R9000 and get a R7800.
pepperoni
Feb 23, 2018Star
This is what they are referring to, "Enable Wireless Router Radio" is unchecked, but the "Broadcast Name" is still transmitting.
