  • dumbttt wrote:
    I'm following the instructions from here:
    https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
    The lights blink, router turns off and restarts but keeps all the same settings. How do I factory reset this router? Any ideas?
    I have the latest firmware version:  V1.0.4.128_10.0.104
    You might want to try a little longer than 7 seconds.  It is not a precision part of the operation unless you cut it too short.
    Ten to fifteen seconds will not hurt.  You will know you have been successful when the default SSID on the label starts broadcasting over Wi-Fi.  I have seen some devices that took more than one reset to be successful.
  • plemans's avatar
    You could also try doing it through the gui.
