up4it1023
Dec 01, 2023Aspirant
check Firmware Error
I've never downloaded a firmware update to my R7000 router. When I purchased it, the big thing was Genie. Now everything is done through the Nighthawk App. My current firmware is v1.0.8.34. When I check for updates on my app it gives me a 'check firmware error'. I know there is an update to the firmware and i have downloaded it to my desktop, however my user's manual does not cover manual firmware updates. I googled how and it says to connect my computer to my router using an ethernet cable but i can't do that since the router's only ethernet cable is attached to the modem. If i disconnect the modem from the router and connect the router to my computer i won't be able to connect to router via Wi-Fi. Maybe that's my problem - i don't know how to connect to my router via ethernet?
Any help would be much appreciated!
Most likely the system won't update since it's kind far behind so ya, you'll need to manually update:
Does your PC have a ethernet port? Can connect the ethernet port to the back of the router then connect to the routers web page to manually update using a web browser.
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
They make inexpensive USB to ethernet adapters as well if your PC doesn't have a Ethernet port.
