ledzep60
May 26, 2021Tutor
cm1200 & R7000 intermittently dropping internet connection but wifi is still on
Hello, maybe someone can help with this issue. I have a CM1200 modem and R7000 wifi router. Over the past 4 weeks we will loose internet connection but the wifi is on. Every device we have is wireless. We have 3 firesticks and 1 firecube, 3 laptops and 3 iphones. When the internet connection drops all devices are affected. The internet light on the CM1200 is on solid, the internet light on the R7000 is blinking as normal, yet we have no internet connection. The R7000 is updted to the latest version and our cable provider is Spectrum. They have checked the modem and it is at the correct version. Does anyone have any ideas as to why this is happening?
thanks
what actual firmware is on the r7000?
What fixes the issue?
- ledzep60Tutor
the latest 1.0.11.122
- ledzep60Tutor
The issue isn't fixed, still happens many times a day. Spectrum has been here 3 times and tested the line right up to the modem and found no issues. But like normal when they are here everything works and the last tech was here it dropped within 10 minutes after he left.
