Flash7Gordon
Nov 24, 2015Guide
Comcast/Nighthawk IP assignment conflict?
Hi, I recently installed my new Nighthawk, I am impressed and it is working pretty well. But I have a Comcast ISP and they give you a router as part of the cable modem. That Router assigns 10.0....
- Nov 25, 2015
AP Mode is not the default setting and I don't think the R7000 would have enabled it by itself. You may have been asked during initial setup whether you wanted to set it up as an AP.
In any case, now that we've established that AP Mode is enabled, the R7000 is not acting as a DHCP server. The R7000 will relay DHCP messages back and forth between attached clients and your Comcast router.
If you are not using the Comcast wireless network, then you should turn it off. It'll free up the wireless channel plus remove one thing for people to hack.
Flash7Gordon
Nov 25, 2015Guide
I appreciate both of your replies and they are guiding my thinking in this matter. But I wish to be a little contrary now. I am looking at the comcast admin attached devices and the nighthawk admin attached devices and somehow they both seem to be able to see devices that are attached to the other router (my nighthawk can see the computers i have ethernet wire connected to the comcast router, which in my mind would be the "blind spot" if there was one). So if they see those devices they can probably avoid assigning ip's on top of each other.
Retired_Member
Nov 25, 2015- TheEtherNov 25, 2015Guru
Double NAT is certainly a concern but it's unrelated to the question at hand of the same subnet being used on the Internet and LAN ports of a router. The latter is a no-no and will only lead to grief. I believe Flash7Gordon is either very lucky that an IP address collision hasn't happened or he has enabled AP Mode on the R7000. If he has enabled AP Mode, then everything is ok because the router and DHCP server functionality are disabled.
Flash7Gordon, do you have AP Mode enabled?
If AP Mode is disabled, then can you provide the IP address and subnet mask information from the Internet Setup AND the LAN Setup pages? I'm very doubtful that the R7000 would permit the same subnet on both ports.
- Flash7GordonNov 25, 2015Guide
Ether, Ok, I'm looking at Advanced Settings -> Wireless AP it's a funny page and has a diagram at the top of it, not the normal place I would expect to see a parameter setting check box. The box for "Enable AP Mode" is checked just above the diagram. I didn't check that after the installation, it was either the defualt or the r7000 figured it out. But I believe I have DHCP mode functionality on the r7000. Lot's of wireless devices are connecting to the r7000 and it's giving them an ip address. I know my mobile stuff ins't connecting to the comcast wireless because it has a long gory password and I can't figure out how to change it. My r7000 is ethernet plugged into one of the 4 wired ethernet ports on the comcast router/surfboard.
