Dozr
Nov 30, 2017Aspirant
Compability with windows 10?
Ordered a WiFi Router, Netgear R8000 Nighthawk X6 3.2 Gbit/s a few days ago. And NOW tonight i got info that it doesnt work with win 10? Is this correct?😣
- Dec 01, 2017
Your friend is not the expert they claim.
Routers do not install, or need, drivers in Windows. They just provide standard Ethernet.
If they had problems in Windows 10, it is because they did not understand how Ethernet works in this operating system.
Any drivers come with the PC's Ethernet hardware. At the beginning, some LAN stuff had problems because the generic drivers in Windows 10 were no good. You had to get the right drivers for the LAN chips on your PC.
The next time you have computer questions, try asking someone else.
TheEther
Nov 30, 2017Guru
Definitely not correct. Where did you get your info?
- DozrDec 01, 2017AspirantGood! Got this info from a friend. And I thought he knew what he was talking about. Became unsure,.. and after some research on my own it didnt make sense. (And found this site)Is there anything I should think about before installing this product with win 10? Can't find much info in swedish.. happy to get info in here instead👍🏼
- michaelkenwardDec 01, 2017Guru - Experienced User
- DozrDec 01, 2017Aspirant🤣 I will ask someone else. Red about this router and decided that it was a good choice. Because I'm learning as I go.. by myself... I became worried that I got it all wrong. And when he dropped this on me... a real syntax error appeared in my brain. Haha... thanks for your quick response/ Linda
