saintssuperdome
Sep 28, 2016Aspirant
Compatible Modems from Charter for NetGear r7000 nighthawk
Is there a list of compatible modems for the R7000 Netgear Nighthawk? I have Charter, and I am wondering if the modem is not compatible.
- Retired_MemberSep 28, 2016
If there is such a list I've never seen it. I would expect any charter supported Docsis 3 modem would work.
- Retired_Member
- saintssuperdomeAspirant
Thanks. This router is set up, but once you are connected you can't get out to the internet.
- Retired_Member
reset modem after 5 minutes connect router then turn it on
