Philippe2021's avatar
Jun 11, 2021
Connecting two linux PCs by ssh
Hello,
I have two Ubuntu PCs on my network. I can use ssh from one PC to the other one if they are connected by ethernet to the router. I can't if one of the two PCs is connected by wifi.
I read here https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/ssh-problem-with-wifi-on-XR500-but-works-fine-via-ethernet/m-p/1709736/highlight/true#M8367 that someone had the same problem.
This person enabled HT160 in the advanced settings of the wifi.
The point is that I cannot enable HT160. I check HT160, I click "Appy" and nothing happens. The button does not work.
I use Chrome. Should I try another navigator ?
Could you help me thanks in advance
  • > Model: XR500|Nighthawk Pro Gaming Router
       Firmware version?
    > [...] I can use ssh from one PC to the other one if they are connected
    > wifi. [...]
       Which kind of "can't"?  Actual error message?
    > I read here [...]
       Note that that fellow found the appropriate forum for an XR500.
    • Philippe2021's avatar
      Philippe2021
      Guide
      can't means that there is no error message. Even a ping does not work.I write "ssh <pc2>" in a bash shell from <pc1> and just nothing happens if one of the two PCs is connected to the router by wifi.
        Philippe2021
        Guide
        firmware V2.3.2.114
        I also have problems with my printer. Print jobs are stuck, and I have to retry and finally the page is printed...
        I start thinking that this router is just bugged and I'm going to return it if my intuition is correct...
  • > It's simple: I have <pc1> and <pc2> (it's 192.168.1.30 and 192.168.1.2
    > but what's the point ?).
       It's _not_ simple.  As I always say, "Everything's complicated."
    > From a shell prompt in <pc1>, ssh <pc2> [...]
       Which part of "actual actions (commands)" was unclear?  What, exactly
    is "<pc2>"?
    > [...] Especially when using a command-line program, copy+paste is your
    > friend.
       Still true.
       A _computer_ does not have an IP address; a network _interface_ has
    an IP address.  If a computer has more than one active network
    interface, then each one must have its own IP address.  If you're trying
    to reach a computer's wireless interface at the IP address of that
    computer's (disconnected) Ethernet interface, then I'd expect problems.
       Even if only network interface is active at a time, if it gets its
    address (and other parameters) using DHCP, then I'd expect each
    interface to get a unique IP address, because each interface has its own
    unique MAC address.
       I still know nothing about the XR500, but its User Manual suggests
    that the Device Manager in its management web site will report on the
    attached devices.  I'd look closely at that report when you switch
    between Ethernet and wireless on one of your <pcX> systems.
    > [...] it's just stuck [...]
       How long did you wait?  Give it a few minutes, not only a few
    seconds?
    > [...] I don't know why. [...]
       I knew that.  That's why we're here.
    > [...] What else can I say ? [...]
       You could answer the questions as asked, with "actual actions
    (commands) with their actual results (error messages, [...]", and not
    simplify, generalize, or pre-analyze anything.
    > [...] And by the way, that did not solve the problem either.
       I doubt that the "NetDuma Partner" fellow in that other thread
    actually believed that that setting made any difference...
    > [...] I would not have guessed that would have affected it but happy
    > you managed to resolve it!
    ...but if the user is happy, it's easier to stop troubleshooting than to
    try to find out what actually happened.  Few people have the patience
    and discipline to change only one thing at a time, so a statement like
    "I did X, and now it works" can be misleading.
      Philippe2021
      Guide
      I pick the IP adress in the Web interface of the router of course.
      What, exactly
      is "<pc2>"
      <pc2> is an IP adress. Right now, my laptop computer is on wifi, and my desktop computer always on ethernet, and I have that from my desktop (mars):
      XXX@mars:~$ ssh 192.168.1.4
      ^C
      XXX@mars:~$ ping 192.168.1.4
      PING 192.168.1.4 (192.168.1.4) 56(84) bytes of data.
      64 octets de 192.168.1.4 : icmp_seq=1 ttl=64 temps=198 ms
      64 octets de 192.168.1.4 : icmp_seq=2 ttl=64 temps=16.4 ms
      ^C
      --- statistiques ping 192.168.1.4 ---
      2 paquets transmis, 2 reçus, 0 % paquets perdus, temps 1002 ms
      rtt min/avg/max/mdev = 16.434/107.459/198.484/91.025 ms
      My desktop computer can ping 192.168.1.4 which is my laptop on wifi but not get a ssh connection.
      Even a
      dmesg
      does not give any information, not even a timeout message. The wifi blocks ssh for some reason (the port 22 is blocked maybe for some reason).
        Philippe2021
        Guide
        I can give the logs of the router but that won't help I guess.
        [admin login] from source 192.168.1.30, Saturday, June 12, 2021 08:16:44
        [DoS Attack: SYN/ACK Scan] from source: 52.162.107.6, port 443, Saturday, June 12, 2021 08:11:20
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:49:19
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:48:39
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:48:39
        [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:48:39
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:48:28
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:46:58
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:46:29
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:46:14
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:45:28
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:44:53
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:44:53
        [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:44:53
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:44:27
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:44:27
        [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:44:27
        [DumaOS] Using disabled(NOP) QoS subclass, Saturday, June 12, 2021 07:44:26
        [DumaOS] Using disabled(NOP) QoS subclass, Saturday, June 12, 2021 07:44:25
        [DumaOS] Using disabled(NOP) QoS subclass, Saturday, June 12, 2021 07:44:24
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:43:28
        [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:43:28
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:42:36
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:42:04
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:42:04
        [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:42:04
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:41:06
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:40:25
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:40:14
        [admin login] from source 192.168.1.30, Saturday, June 12, 2021 07:39:21
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:39:16
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:39:15
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:39:15
        [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:39:15
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:38:59
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:38:53
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:38:47
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:38:47
        [DHCP IP: 192.168.1.4] to MAC address 9c:b6:d0:8d:a5:3f, Saturday, June 12, 2021 07:38:47
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:38:16
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:37:46
        [admin login] from source 192.168.1.4, Saturday, June 12, 2021 07:36:53
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:36:46
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:36:16
        [DumaOS] DHCP new lease allocated., Saturday, June 12, 2021 07:35:44
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:35:44
        [DHCP IP: 192.168.1.4] to MAC address 9c:b6:d0:8d:a5:3f, Saturday, June 12, 2021 07:35:44
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:35:20
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:34:46
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:33:38
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:33:38
        [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:33:38
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:33:12
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:32:54
        [DoS Attack: SYN/ACK Scan] from source: 52.162.107.6, port 443, Saturday, June 12, 2021 07:32:49
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:32:47
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:32:22
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:31:42
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:30:42
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:30:12
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:29:38
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:28:55
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:28:29
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:28:13
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:27:25
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:25:55
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:24:34
        [DumaOS] DHCP new lease allocated., Saturday, June 12, 2021 07:24:12
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:24:12
        [DHCP IP: 192.168.1.11] to MAC address 48:b0:2d:09:8a:35, Saturday, June 12, 2021 07:24:12
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:23:53
        [admin login] from source 192.168.1.30, Saturday, June 12, 2021 07:23:51
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:22:59
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:22:28
        [DumaOS] DHCP lease change., Saturday, June 12, 2021 07:22:25
        [DumaOS] DHCP new event., Saturday, June 12, 2021 07:22:25
        [DHCP IP: 192.168.1.3] to MAC address 24:20:c7:1c:42:c9, Saturday, June 12, 2021 07:22:25
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:22:13
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:21:29
        [DumaOS] Marking device that is marked 192.168.1.3 11 10., Saturday, June 12, 2021 07:19:59
