Tio1's avatar
Tio1
Connectivity to the router C7800
Yes, where I live I have a dish satellite from AT&T. I would like to find out if the router C7800 is compatible, to connect to the router.
  • plemans's avatar
    The C7800 is a coaxial modem device. Its not capable of connecting with dish service.
    You could get a router only device and connec to your current gateway. There'd be a few settings to change but it should work.
    • Tio1's avatar
      Tio1
      Ok thanks
      What about the model C1900 cable modem router it could help me about the connection?
      Thank you again.
      • plemans's avatar
        Not sure what you mean by "It could help me about the connection"?
        A coaxial modem connects to coax isp like xfinity/cox/spectrum.
        If you've already got a gateway from your dish services then you'd want just a standard router like the R**** series of routers.
        here's the series:
        CM: coaxial modem only
        C****: coaxial modem/router
        R****: router only models
        RAX: AX routers
        D****: DSL modem/router devices
        EX: extenders
        EAX: AX extenders
    • antinode's avatar
      antinode
      Guru
      > The C7800 is a coaxial modem device. [...]
         "coaxial" is not the important part.  A satellite gizmo might use
      coaxial cable, too.  What matters is what's at the other end of that
      coaxial cable.  A Netgear model Cxxxx, CAXxxx, or CMxxxx expects to talk
      to a cable-TV ISP, not to some satellite gizmo.
      > What about the model C1900 cable modem router [...]
         Not a Netgear model number.
