scar69's avatar
scar69
Constant Router Disconnect
Since last bios update on my router, my xbox will not stay connected.  Constant connect and disconnect, back and forth.
My xbox is hard wired, not wifi.
Also web pages on both my laptop and desktop have issues loading.  All 3 are up to date with their updates
How can I fix this?
  • FURRYe38's avatar
    • scar69's avatar
      scar69
      My cable modem is a Motorola Surfboard SB6141. My Nighthawk router is a R8000P.
      Everything worked fine before the firmware update
      My firmware update was to V1.4.2.84_1.3.42.
      That is when everything broke.
      Xbox was a constant disconnect.  Computers had trouble loading about anywebpage.
      I just reverted back to V1.4.1.68_1.3.28, about 30 minutes ago.
      Everything went back to working normally.
      My 2 tv's and xbox are hardwired to the Nighthawk.
      My desktop and laptop and wireless.
      There are many other wifi's here.  I live in an apartment
      • FURRYe38's avatar
        Next time, try a factory reset and setup from scratch after a FW update.
        I guess use whats working for now.
