WinterMute
Jul 15, 2015Star
Could just use some positioning suggestions
Hey gang: I just need a bit of guidance as I try to resolve a signal problem. I've got: - A Nighthawk R8000 router - A Nighthawk R7000 range extender - An EX1200 range extender Here's my dilemm...
- Jul 15, 2015
WinterMute wrote: I'd considered an idea: does anyone know if FastLane boosts signal strength? I'd considered the EX7000 being FastLane to the router on the 5GHz and then maybe the EX1200 being FastLane to the EX7000 on 2.4GHz.
But I can't tell if that's just crazy talk...
Here's a link on this forum, that discusses the R8000 and EX7000, in the configuration you are looking for. The thing with the extender, is that you will need decent wireless signal between both devices, so you may have to move your devices around, until you have a strong wireless signal between the two devices.
http://forum1.netgear.com/showthread.php?t=95376
netwrks
Jul 15, 2015Master
WinterMute wrote: Sorry, I said "R7000" when I meant "EX7000". My apologies, brainy no worky sometimes.
If it was me, I would go through great lengths to run a CAT6 cable between the 8000 and EX7000, then turn EX7000 into an AP.
