tirohn's avatar
tirohn
Tutor
Jun 15, 2017
Cujo and Nighthawk R7800
Hi there   I'm trying to get my network a bit more secure and installed the Cujo device. Now I seem to have a bit screwed my network, since I receive around 7000 threats per day, which is quite unu...
  • FURRYe38's avatar
    Jun 15, 2017
    If your trying to use some firewall device after the ISP modem then yes. Use the R7800 as a LAN to LAN AP. Configure it in AP mode. You need only one DHCP server, not more then that. Double NAT condiitions can cause problems.
