popcorn9499's avatar
popcorn9499
Date and time not getting set correctly
So ive been having problems with my router not getting date and time correctly. I got this router from the store a few weeks ago. Only had one fairly minor issue with it. the network assigned time isnt working. The logs dont show too much. But since im no expert on this system nor the logging methods ill send them all. http://pastebin.com/4W3WeEP6. Its just it keeps saying the date and time is january x 2015 it will keep counting up from then a factory reset doesnt matter and it only did this when i did the firmware update from the old firmware it was running when i bought it. I'm unsure what is the real problem. the link proving the system time on this router is right here => link.
And yes the time zone settings r fine on this router i think. link
Firmware Version
V1.0.5.70_1.1.91
im unsure what else is relevent to this. If more information is needed ill provide.
  • ya the fix was update to the newer version 1.0.7.2_1.1.93 and the system time corrected itself
    • Retired_Member's avatar
      Retired_Member
      How is the router connected to modem, The Wan port must be used. What modem are you using.
      • popcorn9499's avatar
        popcorn9499
        in response to searay yes the wan port is being used and before I did the firmware upgrade on the nighthawk from the firmware it orriginally came with the time syncronization worked then on the old version. It quit working on the new version. Sadly idk the version it used to be running. And The modem isnt a modem Its a router that my isp gave us put into lan subports so our tv system still works. But like I said it worked before. it was a pace 5168n router though.
  • On the LOGGING tab under ADMINISTRATION (ADVANCED) is "Router operation (startup, get time etc)" checked?
    The LOG entries for time should look like this:
    [Time synchronized with NTP server] Tuesday, Jul 12,2016 06:21:03
    [Internet connected] IP address: 184.88.19.241, Tuesday, Jul 12,2016 06:21:02
    I noticed you have TRAFFIC METER enabled. Turn it off and see if it still happens after a re-boot.
    Others have reported the same here and have called Support and gotten a special Beta F/W for it and it fixed it.
    Also see this one, https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Time-and-date-is-wrong/m-p/1059600#M28642, it was a DNS problem.
      popcorn9499
      I think ive proven that its not the traffic meter messing up this. http://pastebin.com/XptdLain Checked system time after and it still didnt seemt to be working.
      I also tried changing the dns records to these from google. The ones on the other forum  didnt give me and websites or any changes in this either
      googles dns
      Primary = 8.8.8.8.8
      Secondary = 8.8.4.4
      and the ones from the other post didnt seem to work at all https://i.imgur.com/8O8eaXL.png
      and the logs from this test with the google one that actually gave me internet and not no dns. http://pastebin.com/4rYaWbVs
      The only thing i havent tested is the beta firmware by contacting support which ill probly do later today or something.
