tron76
Mar 09, 2021Tutor
Device limit issue
I purchased this router in January. Worked great until I got more than 15 devices connected. Once I started to get more than this, devices would show they were connected to the router but without internet. If I disconnected (Turned off and on) the device, it instantly had internet again. Netgear hasn't given me a solution that works yet (change DNS, update firmware, Factory reset, Change channels) so I'm rather frustrated. These are the only routers I've used the last 15+ years, so I can hardly believe this has been going on for 2 full months. Any ideas?
What firmware version are you currently on?
What modem is it connected to?
- tron76Tutor
Currently, 1.3.2.124, but I've also used the latest and 2 Versions before. The modem is a Motorola. It is fine because I used the old modem today and worked fine.
That is a brand, not a model. Motorola has made many modems over the years.
