Umrk
Jun 03, 2018Tutor
DFS, Netgear Downloader, and other Undocumented Features
After the firmware V 1.0.2.10_10.0.29, I found Netgear downloader and received an error message when changing the 5 ghz channel warning me about using DFS. Where can I find documentation on this and ...
- Jun 04, 2018
Find the release notes for the latest firmware here:
R7900 Firmware Version 1.0.2.10 | Answer | NETGEAR Support
If you jumped more than one version, then older release notes may help.
There is a support stuff and manual for the R7900 somewhere at the end of this link:
>>>> R7900 | Product | Support | NETGEAR <<<<
michaelkenward
Jun 04, 2018Guru - Experienced User
- UmrkJun 05, 2018Tutor
Thank you for the informartive reply. This firmware update seems to have caused a lot of unexplainable issues that I am trying to work through. One of the more annoying is the inability to restore duel channel 5 ghz channels. I had combinded both into a single 5ghz channel which worked fine until this DFS restreiction sddenely appeared. It made using both channels as a single access point impossible because one of the channels violated this "DFS:" restriction. Another issue is the ossicillating speed of my connection, dropping to 5 mb/s then increasing to 97...its an annoying rollercoaster ride that doesn't seem to stop.
I will be immersing myself in the documentation you provided in hopes of discovering how I might resolve this.
Thanks again!
Umrk
And by the way, what is the benefit of this "Downloader" feature?
- michaelkenwardJun 05, 2018Guru - Experienced User
Torrents?
A technology that dates back to slow internet and that no longer means much. To me at least.
- schumakuJun 05, 2018Guru - Experienced User
DFS is not a restiction, no violation - it's a behaviour required by regulatory requirements for using certain 5 GHz bands or channels. Before any activity can happen, the radio must check of there is certain activity (ie. radar), this takes either 60 seconds (US, EU) or up to 10 minutes (CN, AUS). And during operation, any kind of radar interference must lead to a dynamic channel change, too.
I don't understand what you want to describe with "dual channel 5 GHz channels" or a "combinded both into a single 5ghz channel".
FMI: https://www.smallnetbuilder.com/basics/wireless-basics/33082-smallnetbuilder-s-wi-fi-dynamic-frequency-selection-dfs-faqDFS does not restrict or interfere with the ability of configuring network names (ESSIDs). To use the same network name on both 5GHZ radios resp. all radios, you might have to use the SmartConnect feature. Anyway, there is no "logical" reason why some routers are prohibiting the configuration of the same network name by the way.
