Umrk
Jun 03, 2018Tutor
DFS, Netgear Downloader, and other Undocumented Features
After the firmware V 1.0.2.10_10.0.29, I found Netgear downloader and received an error message when changing the 5 ghz channel warning me about using DFS. Where can I find documentation on this and ...
- Jun 04, 2018
Find the release notes for the latest firmware here:
R7900 Firmware Version 1.0.2.10 | Answer | NETGEAR Support
If you jumped more than one version, then older release notes may help.
There is a support stuff and manual for the R7900 somewhere at the end of this link:
>>>> R7900 | Product | Support | NETGEAR <<<<
Umrk
Jun 05, 2018Tutor
Thank you for the informartive reply. This firmware update seems to have caused a lot of unexplainable issues that I am trying to work through. One of the more annoying is the inability to restore duel channel 5 ghz channels. I had combinded both into a single 5ghz channel which worked fine until this DFS restreiction sddenely appeared. It made using both channels as a single access point impossible because one of the channels violated this "DFS:" restriction. Another issue is the ossicillating speed of my connection, dropping to 5 mb/s then increasing to 97...its an annoying rollercoaster ride that doesn't seem to stop.
I will be immersing myself in the documentation you provided in hopes of discovering how I might resolve this.
Thanks again!
Umrk
Umrk
Jun 05, 2018Tutor
And by the way, what is the benefit of this "Downloader" feature?
- michaelkenwardJun 05, 2018Guru - Experienced User
Torrents?
A technology that dates back to slow internet and that no longer means much. To me at least.
- TerryPhJun 05, 2018Virtuoso
BT - not much used anymore. We have now Gigabit Internet speed....
