ShaunSs's avatar
ShaunSs
Does Ap mode fix double Nat?
Hello I have an nighthawk R7000 and I am getting double Nat on my Xbox one does turning on access point mode in my router settings fix this problem?
  • > [...] I have an nighthawk R7000 [...]
       Connected to what?
    > [...] does turning on access point mode in my router settings fix this
    > problem?
       It might.  Cascading multiple NAT routers causes it.  Using only one
    NAT router (as a NAT router) should eliminate it.
    • ShaunSs's avatar
      ShaunSs
      I have just the 1 netgear night hawk router in my home should i give it an try? Or could i screw  something up big time?
      • ShaunSs's avatar
        ShaunSs
        it connected to satilite dish out to ISP since i live on an farm it is not wired in
