Juan31's avatar
Juan31
Don't see wifi 6 channel
I've read a similar post here but no answer. Question is why do I not see an option to connect to wifi 6 channel? I have a device that is wifi 6 but no option to connect to wifi 6. Only shows the 2.4 and 5g. Please help had router since may and still can't figure it out.
  • schumaku's avatar
    schumaku
    What router model and firmware version please?
    What device make, model, WiFi adapter and OS are we facing here?
    Suspect you are confused by the designations. WiFi 6 does not say it does support the 6 GHz channels - that would be WiFi 6E.
    • Juan31's avatar
      Juan31
      Ax11000 RaxE500 router. Firmware v1. 0.7.68 so what you are saying is even tho I have a device connected to 5g channel it connects as 6g?
      • plemans's avatar
        What "wifi 6" device do you have?
        Wifi 5 is just 2.4ghz/5ghz.
        6E is the 6ghz spectrum.
        So letting us know what actual device you have will help us determine if it actually has 6ghz capabilities.
