MarMD's avatar
MarMD
DoS Attack disable my wifi
recenly my wifi keep discontecting. i have to reboot to get it back
my router is the latest version .
i did factory reset which didn't help . i downgraded it to the previous version (see the picture) it didn't help it keep disabling my all my wifi. the 2.4 and 5ghz LED light on router still blinking though
i checked my log . not sure if this related to DoS Attack . it looks that this happen every time after a DoS Attack.
i will try (but i am not happy ) to disable  the Disable Port Scan and DoS Protection to see if this will help
if anybody have  some solution please share. hope netgear can fix this in the future
Log:
[Time synchronized with NTP server] Sunday, November 15, 2020 20:45:36
[Internet connected] IP address: 68.105.198.116, Sunday, November 15, 2020 20:45:33
[Internet disconnected] Sunday, November 15, 2020 20:45:27
[DoS Attack: ACK Scan] from source: 167.250.203.23, port 48239, Sunday, November 15, 2020 20:21:29
    • MarMD's avatar
      MarMD
      Disable Port Scan and DoS Protection didn't help
      i did change the default MAC address of the router this actually helps. I am still having those “DoS Attack: ACK Scan” i have not noted any disconnection however based on a log file it happened overnight a starting of  Firmware  which may indicate a router reset.   instead of happening every hour,  now it is happening every two days which is good somehow .  netgear has to work in fixing this issues in its next firmware upgrade
  • as follow up!
    It looks like nothing works . downgrading, or changing MAC address didn’t work. I ordered another router. Eventually  this attack stopped and the router was working well for the past week.
