TheEther
Dec 02, 2015Guru
downloadcenter.netgear.com appears to be down
downloadcenter.netgear.com appears to be down. It's pingable but not responding to http.
downloadcenter.netgear.com is back up.
- echotronAspirant
i have the same problem i can't down load up date!
Still down today. This time I'm getting a 404, which means that someone restarted the http server but now the webpages are gone. Hopefully, the Netgear folks are in the middle of doing maintenance.
- rpoffenVirtuoso
Hmm, I just downloaded the latest R7000 firmware file (1.0.5.48_1.1.79) and had no problem. I just clicked on the link from the main R7000 support page.
There's still some funkiness. If you click on GET MORE DOWNLOADS, it'll try to take you to downloadcenter.netgear.com and fail.
