avis123
Feb 15, 2019Tutor
Error Message: Warning: Ther router is failed to connect to NTP server, please check your Internet
Hello,
I am having issues with the Date NS RIMW OD my R7000 NightHawk router. Those are showing incorrectly. I need to schedule router downtime. However, since the router time is showing incorrectly the scheduling is getting messed up as the scheduling time (I believe) works based on the router time. I am attaching a screen shot of the NTP setting where the probem is. I have not yet been able to find a solution yet though I tried to use Google NTP server time.
I would appreciate any help towards resolution of this issue. Thanks in advance.
Suggests something else is amiss.
Note that shadowsports appears to be running older firmware on an R7000. Might be worth trying that.
Your version has been fingered as "problematic" (broken) in other areas. Maybe you have discovered a new defect.
Have you ever done a factory reset? Might be worth trying.
Does the default NTP server work?
I can confirm the default NTP server works in 1.0.9.42.
I have Comcast (ISP)
That's good.
Now we need to know why avis123 wants to user an alternative NTP server.
