Tulsatime
Dec 02, 2020Tutor
EX6200 difficulty
I was doing a firmware update tonight. I think this thing is bricked. Upon power on the two network lights are amber and the connectivity arrows are flashing green. I cannot get the factory reset button to do anything.
How can I reserect this thing where I can log into it and get it working? I cannot see it on wireless to connect and have tried a direct enet connection as well. no joy.
thank you.
glad to hear it fixed it!
If you mark it solved, it might help the next person with that issue.
You might be a candidate for a tftp or nmrpflash recovery.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
One thing you could tryu before you go down tne TFTP road is the recovery reset.
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, a conventional firmware update may work. If it fails, then, as plemans says, TFTP is your friend.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR CommunitiesAll great ideas! Thanks for the two tips...will be working on it today and will advise how it turns out.
