bzyc
Nov 26, 2021Tutor
EX6250 Mesh Extender doesn't connect anymore
Most recent Android app update made me unable to use my mesh extender EX6250. I've since factory reset the extender, and tried to reconnect, but the app keeps crashing when "personalizing settings" du...
michaelkenward
Nov 26, 2021Guru - Experienced User
bzyc wrote:
I've since factory reset the extender, and tried to reconnect, but the app keeps crashing when "personalizing settings" during setup.
Netgear's apps are famously flaky.
Have you tried setting it up with a browser? Wired is preferable, but if you can connect to the wifi that may also work.
One configured you may find that the app works.
