tdavison1962
Sep 30, 2022Aspirant
Firmware upgrade getting stuck on language file - Nighthawk R7900P
I am attempting to upgrade my Nighthawk firmware and getting stuck on the message: Upgrading language file. It will not get past this message and upgrade the firmware.
| Firmware Version | V1.4.1.68_1.3.28 |
| GUI Language Version | V1.4.1.66_2.1.46.1 |
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Are you using the routers auto update feature or manually applying the FW update file?
- tdavison1962Aspirant
Thank you, that worked great
Enjoy. 📡
