Thomaslamf
May 26, 2021Aspirant
Help to Remove DD-WRT Firmware from R700 Nighthawk
Hi,
Just after some help to Remove DD-WRT Firmware from R700 Nighthawk, I have tried below but it doesn’t seem to work for me unless I’m doing something wrong help would be much appreciated. Thanks
https://kb.netgear.com/19841/Reinstall-the-firmware-on-a-router-without-the-setup-CD-recovery-tool
Check on the ddwrt forum. their the experts on removing their firmware from a device.
- ThomaslamfAspirant
Ive been trying to register to add a post but, it never works always says the bot code is wrong when its right. plemans
Not sure what you expect the netgear forums to do for a ddwrt issue.
Again, use their forums for their firmware. Or your likely to brick your device
