nhatey's avatar
nhatey
High ping to local router (Nighthawk ac1900 R7000)
I've suddenly gotten high ping. Router was working fine and was stable since October.
When pinging via CMD : ping 192.168.1.1 -t
on both 2.4 and 5ghz I find the ping to spike a lot going from 1 to 30 and sometimes 100+ ms. This is a lot worse on 2.4ghz.
If there is high ping between my router and my PC, that would undoubtedly make the ping to the internet high aswell (which I am experiencing).
I've tried changing channels, and making sure no one else is on that channel as well as disabling QOS.
  • plemans's avatar
    What firmware is on your router?
    Do all devices have the same issue? or just the one?
    • nhatey's avatar
      nhatey
      High ping is on all devices. Firmware is up to date, just checked last night
      • plemans's avatar
        what actual firmware are you on?
        the R7000 is knowns for saying "up to day" when its not.
        what modem are you using?
