NetGearHead5's avatar
Nov 20, 2013
How do I reset my R7000 back to the state in which I pulled it out of the box?
How do I reset my R7000 back to the state in which I pulled it out of the box? Why am I asking? The most recent release of firmware has destroyed my router's connectivity and performance. I'm having to deal with devices that can't connect, devices that drop off, extremely poor performance, etc. It's just a disaster.
I've been with Netgear 5-6 years and had to do something last night I've never had to do before - I had to revert back to a previous release of the firmware. Honestly, very little was working well. The previous release of software had a few hiccups here and there but the newest release is just a nightmare.
Now that I applied a previous release of the firmware though, I still see some of the newer options that weren't there before. I took notice that the firmware was now the prior release but the GUI is still the current release.
Just to give some perspective, on my Nexus 5 running 802.11ac, prior to the current release, I could peg 90Mbps+. Since the new release, the best I can do standing right next to the router is 24Mpbs+. Even after rolling back to the previous firmware, the speed is still the same.
So, I want to get the router back to the shape as when I pulled it out of the box, apply the previous firmware, and reset up if necessary. I just want my router back prior the most recent release that destroyed it. Again, that release had some hiccups but it was still usable.
  • The 30-30-30 reset method works on the most routers out there but not on the R7000...
    The correct way to reset your R7000 to the Out of the Box State is...
    Download the initial Release from Netgear R7000 Support HP http://downloadcenter.netgear.com/en/product/R7000(Firmware Version 1.0.0.96)
    Reset and flash back from any Stockfirmware to initial Stockfirmware:
    Power on the Router
    wait several seconds
    Hold down Reset for 5 to max 8 seconds ! **
    connect to 192.168.1.1
    flash the initial FW
    now the Router reboots
    ** After every reset, the first login screen on StockFW should show something like "refreshing settings or loading settings"
    Now its like Out of the Box.
    Reset and flash back from any DD-WRT FW to initial Stockfirmware:
    Power on the Router
    telnet into the Router
    run the commands:
    "erase nvram"
    "reboot"
    flash the initial Stockfirmware via the Administration Tab (if the upgrade fails with site not available, try another browser like Firefox, chrome, safari)
    I reflashed several R7000 back to initial Stockfirmware because the latest FW with Beamforming was not stable enough after several Days/Weeks testing...The FW showed some massive connection drops after 24hours and only a Router reboot fixed it (tested on 3x R7000)
    The connection dropped down from 1300 to 66-256 after several Hours.... -.-
    Now i am waiting for a new FW release with Wifi fixes from Netgear.
  • RogerSC wrote:
    Hung, I'd advise you to wait until your router is fully booted before resetting it. You're more likely to get your desired result that way.
    That would be the same as normal factory defaults right, in any case it doesn't help.
    Is there something to resetting short after factory defaults?
    I would like more info like accurate timing, when to do it (which LEDs pattern to look for), and how dangerous this is.
