Don46
Dec 19, 2016Aspirant
How do I set up an Ethernet connection with R7000?
My wireless network is working fine, but I went to some expense to set up ethernet connections to my new home office and to my wife's home office and I want the hard wire connection. I do not see th...
- Jun 04, 2017
After trying everything, I took my desktop into my wife's study, also hard-wired, and it immediately connected via ethernet. So, it had to be bad wiring in my office. It was. The electrician came over, reinstalled the plug on the office end, and it worked fine. I should have suspected the mechanical problem immediately, given that it was new wiring and apparently not tested.
thanks all.
Don
HiSpeed
Dec 19, 2016Guide
Hi,
For all the home/office machines (not roaming), I suggest you to use static addresses.
That's more efficient and avoids troubles with DHCP client/server dialogs.
For example, if your router LAN IP is 192.168.1.1 you can give addresses like 192.168.1.xxx to your PC's (mask 255.255.255.0) with Gateway and DNS set to 192.168.1.1.
