Don46
Dec 19, 2016Aspirant
How do I set up an Ethernet connection with R7000?
My wireless network is working fine, but I went to some expense to set up ethernet connections to my new home office and to my wife's home office and I want the hard wire connection. I do not see th...
- Jun 04, 2017
After trying everything, I took my desktop into my wife's study, also hard-wired, and it immediately connected via ethernet. So, it had to be bad wiring in my office. It was. The electrician came over, reinstalled the plug on the office end, and it worked fine. I should have suspected the mechanical problem immediately, given that it was new wiring and apparently not tested.
thanks all.
Don
Dec 20, 2016Guru - Experienced User
Don46 wrote:
My wireless network is working fine, but I went to some expense to set up ethernet connections to my new home office and to my wife's home office and I want the hard wire connection. I do not see that option. The desktop computer I'm running is a PC w windows 10. I have Netgear Genie up and running.
As others have said, the wired connection is available if you connect up the R7000 LAN ports to your ethernet wiring. There is no setup needed.
But your PC might be choosing the wireless network even though the LAN is available. Try turning off the wifi on the PC. If you have no internet connection after that, try removing/reinserting the ethernet cable in the PC. If that still fails, try a restart of the PC.
Don46
Jun 04, 2017Aspirant
thanks all.
Don
