Ana2
Jun 15, 2021Aspirant
How do I setup a bridge mode on the NETGEAR R7000?
Based on the instruction that came with my Netgear Nighthawk R7000 AC1900 Smart WiFi Router, I disconnected the router provided by my cable company and replaced it with my Netgear router. Although the WiFi is working, I am getting intermittent service on my TV and the internet constantly drops off. Upon reviewing reviewing the communities conversation it looks like I may need to set up a bridge. How do I go about doing that?
> Based on the instruction that came with [...]
_Which_ "instruction"?
> [...] my Netgear Nighthawk R7000 [...]
Firmware version? Connected to what?
If you bought it new, did you try Netgear support?> [...] Upon reviewing reviewing the communities conversation [...]
The whole thing, or some particular parts, or what?> [...] it looks like I may need to set up a bridge. [...]
What, exactly, led you to that conclusion? What, exactly, does "set
up a bridge" mean to you?- Ana2AspirantI followed the manufacturer's instructions that came in the box with the new router. I am using the cable company's modem but replaced their WiFi router with my Netgear 36 nighthawk R7000 router. It worked fine for a while but now my internet connection keeps dropping. After reading the various related issues other users had it seemed like I needed to create a bridge. Based on your feedbacks and since it is a new router I will be contacting their support group. Thank you all for your support.
> the new router. [...]With my weak psychic powers, I can't see them from here. Thus, I
don't know what you read, or what you did.> [...] I am using the cable company's modem [...]
With my weak psychic powers, I can't see it from here. Has it a
maker and model number?> [...] but replaced their WiFi router [...]
maker and model number?> After reading the various related issues other users had it seemed
> like I needed to create a bridge. [...]
With my weak psychic powers, I can't see what you read. "seemed"?> What, exactly, led you to that conclusion? What, exactly, does
> "set up a bridge" mean to you?Which part of "exactly" did you find confusing?
Thanks for answering none of the questions.
> [...] Based on your feedbacks and since it is a new router I will be
> contacting their support group. [...]You might need to provide some useful information, there, too.
What provides the Internet to these routers? There is usually a modem of some sort between the router and the outside world.
Most ISPs supply a modem/router to do that. You cant just remove that and use a router in its place. So what is feeding the R7000?
