AWULF
Jun 06, 2023Aspirant
How to exend my network over Ethernetcable (long distance 50m)
Hello, this might be a stupid question on how to, but everybody using repeaters where the wifi signal overlaps.
In my case I have (an old R7000 Nighthawk).
I want to buy a new one and use the R7000 as a repeater over cable as the current wifi signal is not available 50meters from premise. Or I can buy an extender EAX80. Can use this one using a cable?
A repeater needs to be closer to the current wifi network but that's not feasible.
I need to use the same wifi network for both, can I do this with a cable?
Repeater mode is only connected via wireless. AP mode, for R7000 or EAX, you have to use a ethernet connection to get them connected to work properly in AP Mode.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
- microchip8MasterIn addition, NG firmware doesn't support Repeater mode.
- AWULFAspirantSo basicly. Between ISP and R7000 I have to setup a bridged mode as a router (already in place) and I configure a cabled connection to my extra extender in AP mode.
Cabled network R800 Lan into my Wan port of the extender.- michaelkenwardGuru - Experienced User
You could investigate Powerline Ethernet
