Reaper822's avatar
Reaper822
How to Get a Detailed Internet Usage for Netgear Nighthawk R7000
i have been trying to get a detailed internet usage for my network so i am able to see what devices are uising the internet and how much.  is this possible on the model i have.  The router is using the latest firmware version V1.0.1.44_1.0.1.
Thanks
  • You can get per-IP traffic stats with third-party firmware, Asuswrt-Merlin.  Note, you will lose hardware acceleration, so the max throughput between WAN and LAN will drop to about 450 Mbps.  If you have Gigabit speed Internet, then there may be a noticeable drop in performance.
    The usual caveat emptor applies for third-party firmware.
  • FURRYe38's avatar
    Have you enabled Traffic Meter feature on the Router?
  • Yeah I have but that only gives an overall usage. I want to know how much each device is using
    • TheEther's avatar
      TheEther
      Guru
    • FURRYe38's avatar
      Might try OpenRouter FW as well, however not sure if they support per device stats as it's mostly the same UI. Might beable to though.
