withalligators
Apr 20, 2015Novice
How to maximize speeds with a Broadcom AC card and R7000?
Hello all, I've upgraded my motherboard to a Asus Maximus VII Impact with an onboard Broadcom 802.11AC Network Adapter. I believe it is model BCM43XAC_NT61 based on the device ID. On my 5GHz ban...
- Apr 30, 2015I changed all the settings. Immediately made the signal jump to four bars, and then drop down slowly to 1 or 2. Not much difference in download speed.
But, I got a new modem from Optimum, one with Docsis 3.0, the Arris TG862G, and it allowed my dl speeds to go up to around 7.0 MB/s. Much better.
Should I look into getting one of the high end Surfboard modems to further increase speeds?
And is there anything else you guys can think of regarding the Broadcom card or the router to further increase DL speeds?
This is the antenna that came with my motherboard. Would I be better served with some standard antenna?
Will putting aftermarket antennae like this do anything or is it just gimmicky? How come they don't list it as 802.11ac compliant in the listing?
Thanks again
Cheers
Alex
withalligators
Apr 29, 2015Novice
I think I mistyped the options for Bandwidth Capability
They are:
11a/b/g:20/40MHz
11a/b/g:20MHz
11a:20/40; 11bg:20MHz
Also, there is a wiki entry on Xpress Technology. Can't make heads or tails if it will help me though.
Wired connection isn't an option for me in this room. Maybe a powerline setup would be possible. Or I could just live with mediocre download speeds.
Cheers for the help!
They are:
11a/b/g:20/40MHz
11a/b/g:20MHz
