lalascott7's avatar
lalascott7
I get "issues connecting to.." Error
This is so frustrating!!!! I don't understand what's tiny on with my app but everytime I connect to the right network I still cannot get it to detect my nighthawk router!!! I have tried set up 2xs and I did detect one time then suddenly stopped. Is there a better way to just get this firmware update besides using the app?
  • > [...] my nighthawk router [...]
       Has your (unspecified) "my nighthawk router" a model number?  Look
    for "Model" on the product label.
    > Model: A6200|802.11ac Dual Band WiFi USB Adapter
       Not a router.
    > [...] Is there a better way to just get this firmware update besides
    > using the app?
       _Which_ "this firmware update"?  Are you trying to do a firmware
    update?
       Forget the (unspecified) "my app", and use a web browser?  Visit
    http://netgear.com/support , put in your (actual) model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "firmware".
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Downloads.  (For older versions, under Firmware and
    Software Downloads, look for "View Previous Versions".)  Find the
    kit(s).  Download the kit(s) you want. Read the "Release Notes" file
    for instructions.  (In the User Manual, look for "firmware", and,
    especially, for a topic like "Manually Upload Firmware to the Router".)
       Failing a helpful User Manual:
          https://kb.netgear.com/23960
       Not a router.
    > using the app?
    update?
    • antinode's avatar
      antinode
      Guru
          Note that many people recommend using a computer with a wired
      connection to the router for this, rather than any wirelessly-connected
      device.
    • lalascott7's avatar
      lalascott7
      Ok cool. Yes I realized that about the type of model. It's an R6230 nighthawk dual-band router.
      I am going to go to my pc to install firmware on my device. And I'm going to forget about the app, right? If that's so I appreciate your help. 🙂
