smithjordan2196's avatar
Dec 21, 2020
Im stuck in bridge mode and can't access genie
So i put my router in bridge mode and now i cannot access anything to get it out of bridge mode. I have reset my router almost 20 times and have tried using 5 different computers. I have tried going to routerlogin.net and also just typing in my ip address on all 5 different computers. I can not get anything to help
  • michaelkenward's avatar
    michaelkenward
    smithjordan2196 wrote:
    So i put my router in bridge mode ...
    Is this as a wireless repeater?
    If so you should be able to get at it by aiming a browser at its IP address. The router is just one of several places where the IP address for the  R7450 will be listed.
    You can't use routerlogin.net for something in bridge or AP mode and I have no idea what you mean by "my ip address". It is the IP address of the R7450 that you need.
        michaelkenward
        That depends on the router. You haven't told us what that is.
        By default many brands use 192.168.1.1 or 192.168.0.1 for a modem router.
        If you are connected with a PC to the router, then it should show the IP address in the network settings and properties.
        But if you want to get the IP address of the R7450, then some other network tool should help. If you can connect to its wifi, then the connection's properties should show the IP address.
        If you just want to get it out of bridge mode, read this:
        How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You will have to find the new Ip address of that router. Typically the way to do this is to log into the router that isn't bridged and go to the attached devices find the other router's IP address and then put that IP address in your web browser. That should prompt you with the login for the R7450.
  • DarrenM's avatar
    DarrenM
    It may have brought you your modem login does your modem have a built-in router?
