Wayne1938
Jul 31, 2014Guide
Internet light goes amber on R7000
The internet light will change from white to amber and I have no internet access through the router. This has happened 3 times. The 1st two times I had to do a hard reset though the hole in the back...
- Jul 31, 2014Thanks Sir buzz and Dshed.
Will check the traffic control settings.
My modem is a Motorola 6141 which I will be changing to a Arris/Motorola 6183 when the modem is released for retail in a couple weeks.
The amber light thing came back 3 hours ago. This time I had to take the router totally out of the loop, do a hard re-set, let it set for an hour to get it going again.
I bought the R7000 through Dell using a couple of their discount coupons, about 6 months ago.so called them to get a good number for Netgear warranty and replacement.
Much to my surprise, even though it was past their normal 30 day replacement period, they are going to send me a new R7000 early next week.
I really like this router as I get range on the 2.4, 5.0 and AC bands I didn't think possible, but this amber light thing is getting very frustrating.
Ldyluk10
Nov 04, 2015Aspirant
Ok I am experiencing the same problem but I am not tech savvy at all and have no idea what you guys are telling each other to do to fix it. I just received a new R7000 today through the RMA process and it still goes Amber with no connection. It's really making me mad and frustrated. Can anyone explain how to fix this in laymen terms? I also have an Arris modem from Charter.
JamesGL
Nov 04, 2015NETGEAR Employee Retired
Hi Ldyluk10,
Did the replacement device worked? If did not work, you may need to do a MAC spoofing. Check this article.
http://kb.netgear.com/app/answers/detail/a_id/1086/~/no-internet-with-new-router---mac-spoofing
JamesGL
Community Team
