Wayne1938
Jul 31, 2014Guide
Internet light goes amber on R7000
The internet light will change from white to amber and I have no internet access through the router. This has happened 3 times. The 1st two times I had to do a hard reset though the hole in the back...
- Jul 31, 2014Thanks Sir buzz and Dshed.
Will check the traffic control settings.
My modem is a Motorola 6141 which I will be changing to a Arris/Motorola 6183 when the modem is released for retail in a couple weeks.
The amber light thing came back 3 hours ago. This time I had to take the router totally out of the loop, do a hard re-set, let it set for an hour to get it going again.
I bought the R7000 through Dell using a couple of their discount coupons, about 6 months ago.so called them to get a good number for Netgear warranty and replacement.
Much to my surprise, even though it was past their normal 30 day replacement period, they are going to send me a new R7000 early next week.
I really like this router as I get range on the 2.4, 5.0 and AC bands I didn't think possible, but this amber light thing is getting very frustrating.
Ldyluk10
Nov 05, 2015Aspirant
I don't know what that means. We don't have an Internet limit and the Internet works perfectly when the Ethernet cable is hooked directly to the device in use.
rpoffen
Nov 05, 2015Virtuoso
I believe that he is referring to the traffic limit you can set in the router. This feature is useful for users that have a limit on the amount of data that they can use on a monthly basis from their ISP without incurring extra charges.
It is not strictly related to your ISP's parameters.
