Wayne1938
Jul 31, 2014Guide
Internet light goes amber on R7000
The internet light will change from white to amber and I have no internet access through the router. This has happened 3 times. The 1st two times I had to do a hard reset though the hole in the back...
- Aug 01, 2014Thanks Sir buzz and Dshed.
Will check the traffic control settings.
My modem is a Motorola 6141 which I will be changing to a Arris/Motorola 6183 when the modem is released for retail in a couple weeks.
The amber light thing came back 3 hours ago. This time I had to take the router totally out of the loop, do a hard re-set, let it set for an hour to get it going again.
I bought the R7000 through Dell using a couple of their discount coupons, about 6 months ago.so called them to get a good number for Netgear warranty and replacement.
Much to my surprise, even though it was past their normal 30 day replacement period, they are going to send me a new R7000 early next week.
I really like this router as I get range on the 2.4, 5.0 and AC bands I didn't think possible, but this amber light thing is getting very frustrating.
rdh91007
Jul 31, 2014Guide
Who is your ISP?
What kind of Internet Connection, PPPOE, DHCP?
When you lose Internet Connection what does the router Status Show?
Have you tried to reconnect using the Router's Web Interface?
Does the Router reconnect if you power cycle?
