Wayne1938
Jul 31, 2014Guide
Internet light goes amber on R7000
The internet light will change from white to amber and I have no internet access through the router. This has happened 3 times. The 1st two times I had to do a hard reset though the hole in the back...
- Jul 31, 2014Thanks Sir buzz and Dshed.
Will check the traffic control settings.
My modem is a Motorola 6141 which I will be changing to a Arris/Motorola 6183 when the modem is released for retail in a couple weeks.
The amber light thing came back 3 hours ago. This time I had to take the router totally out of the loop, do a hard re-set, let it set for an hour to get it going again.
I bought the R7000 through Dell using a couple of their discount coupons, about 6 months ago.so called them to get a good number for Netgear warranty and replacement.
Much to my surprise, even though it was past their normal 30 day replacement period, they are going to send me a new R7000 early next week.
I really like this router as I get range on the 2.4, 5.0 and AC bands I didn't think possible, but this amber light thing is getting very frustrating.
RickInJax
Jun 04, 2015Aspirant
CORRECTION:
Sorry... I installed the R7000 last June and the LAN port to my GB switch has been white up until last week.
