Lwilson2k1's avatar
Lwilson2k1
ipv6 issues
I have spectrum
Turned in the ipv6 in modem
DHCP selected
Xbox still not getting an ipv6 address
Did an ipv6 test and it failed.
Spectrum says they aren’t blocking and should be working.
Is there settings to force ipv6 on a device?
Any walkthroughs are appreciated
  • Go to Advanced -> Advanced Setup -> IPv6. You can select there DHCP or Auto Config (SLAAC)
      • microchip8's avatar
        microchip8
        Master
