HammSilv's avatar
HammSilv
Is Nighthawk R7450 PoE Enabled?
Hello all,
I am about to extend the WiFi with a ceiling-mounted AP, so I need to know if the R7450 Nighthawk AC2600 WiFi Router supplies Power over Ethernet through one of the 4 ports.
Thanks.
  • FURRYe38's avatar
    No.
    PoE comes on some LAN switches though.
    • HammSilv's avatar
      HammSilv
      Thanks for the information... I suspected as much since there is no mention anywhere else.
      I really didn't want to pace another node, that's why I was asking.
      • FURRYe38's avatar
        Most home class routers don't support PoE, thats usually kept to the LAN switches.
