Anam's avatar
Anam
Issue With Mac Filtering
Hello,
I just got the X10 and was settying up Mac Filtering on it and found an Issue/Bug with it, after add  couple MAc addresses to allowed list and hit apply it comes back with a grey page and does not respond until you reboot the router. Does anyone know what's causing it?
  • Welcome to the community, Anam
    Try to reinstall the firmware and see if you will experience the same problem.
    After reinstalling, do not forget to factory reset the router then reconfigure it.
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    • Anam's avatar
      Anam
      Ok, Will try it out tonight, thanks for the reply
      • ElaineM's avatar
        ElaineM
        You're welcome. Feel free to give us an update.
